- Nov 22, 2016
- 4
- 1
Greetings everyone.
I am relatively new to the CCTV System business, and I am encountering quiet a snag along the way.
Here it is:
I have a 16 channel NVR - hikvision nvr ds-7732n-e4
and over an assortment of hikvision Ip camera's , e.g. bullet, dome, fish eye, and hey are a mix of indoor and outdoor. All the camera's are suppose to connect to the NVR though UTP cable with POE on each.
BUT - I have more than 16 camera's -( even if i specifically requested a 32 channel nvr I still got sent a 16 chanel one), and the camera's are installed over an array of locations. Which means that some will be over 100m distance from the NVR.
I understand - theoretically - that I can connect the camera's to a poe switch and then connect the switch to the NVR.
ALSO - I have sniffed around on the NVR and there is an option where I can manually add ports, but even if I do that it does not discover the camera's over the switch.
So, What I want to know is how to let the NVR recognize camera's connected to an external switch on the same LAN. Is there a setting or a route I need to add to the switches to pass the connection along?
Any help would be much appreciated.
Chicko~
Here it is:
Chicko~
