I got a 25x Starlight camera last week and got it setup via Blue Iris. Camera works great, but I found that I can't set the presets in Blue Iris. It says it's setting them, but when I try to go to them it goes to the original camera default position on bootup. So I thought I'd try to set them via the camera config itself. According to the documentation, I should go into the PTZ settings, set the menu option to Preset, move the camera to the desired position, enter the preset number and click Add. However, there is no Add button. No Delete button either, which should be there.
