Here is the result:
port 8686 is open? but no access if I try that port.
								It confirms there is not much going on internally.It says, it is up but all ports are closed. Strange.
It will be there - maybe just needs to be recognised.no ttl.
That's a good clear image.Here is a picture.
 . I found this picture of a dahua camera serial connector and figure it's logical that they'd use a standard pinout across all the devices. An oscilloscope would be the best for debugging this. A multimeter would probably work ok to identify the ground pin.
No need to be "sorry", as it was posed in question.Sorry, but neither is useful, and the second is potentially dangerous.
On an NVR, the battery is used to keep the RTC (real time clock) operating when power is off.
The device configuration is stored in files in the flash memory.
