My SD59430U-HNI outdoor PTZ started to exhibit sporadic dropouts. When I checked out the RJ45 connection I found significant water ingress, corrosion and even some "greenery". Cleaning with alcohol swabs did not provide a permanent fix.
I am replacing it by cutting off the old, replacing with a much better sealed unit and making absolutely sure water can't get in.
For any that need to know the RJ45 connection is stock T568B on the camera side.
