I am having a small issue with using the "position" button on the PTZ controls in the cams web interface. I figured the easiest way to explain is to use BI to do a screen capture and show you in a video. Notice once I draw the rectangle it zooms to the incorrect position. I can do this same thing on my other pc running a 27" monitor at 1920x1080 and it works fine. The monitor I am using with the issues is a Acer K272HUL 27" 4k.
Also when I hit the full screen button it of course does not fill the whole screen. I have tried to uninstall the web plugin and cleaned the registry of earlier installs of plugin, but same thing. Both pcs are running W10 x 64 and using IE.
Any suggestions ? or can someone verify this works on 2560x1440 4k display ?
