Running Blue Iris 24/7 on old hardware? You might be paying more than you think…
CrazyAsYou
Getting comfortable
Mar 28, 2018
326
334
England, Near Sheffield
I would like to start by calling out that although I wrote most of this post manually it was a little messy and all over the place, so I use ChatGPT to tidy it up and make it a little more professional.
I’ve been seeing a lot of posts lately where people are running or asking about Blue Iris + AI on older PCs and GPUs — and I get it, we all like to reuse hardware and for many years I did the same with a GTX 970 and Intel i7 Gen6.
But if your system runs 24/7 (which most of ours do), it’s worth stepping back and looking at the total cost, not just the upfront cost.
⚡ Old hardware = hidden running cost​
Older CPUs and GPUs tend to be significantly less power efficient than newer ones. That matters a lot when your machine never turns off.
  • Blue Iris is already CPU-heavy by design, especially with multiple cameras and AI processing
  • Power consumption directly impacts cost because these systems run continuously
  • Some GPU options (especially older GTX 970/980/1080 NVIDIA cards) can actually increase long-term power usage and heat output
So while that old i7 or Xeon + GTX card might feel “free”… it often isn’t.
The bit people overlook: energy cost over time​
Let’s say your older setup pulls an extra 50–100 watts compared to a newer efficient system.
Running 24/7:
  • 50W = ~438 kWh/year
  • 100W = ~876 kWh/year
With current UK electricity prices, that’s easily:
  • £100–£300+ per year (and rising…)
That’s every single year, just to keep older hardware running.
What newer hardware gives you (besides lower power)​
Upgrading doesn’t just save power — you usually get:
  • Faster AI inference times
  • Lower CPU usage (less pegged at 90–100%)
  • Better hardware decoding
  • Smoother UI and remote access
  • Less heat, less noise, more stability
Even modest modern CPUs are far more efficient per watt than older ones.
You don’t have to buy brand new​
This is the key point a lot of people miss:
You can often find much newer, far more efficient hardware for cheap if you look around:
  • eBay
  • Facebook Marketplace
  • Refurb office PCs (Dell OptiPlex, HP Elitedesk, Intel NUC, etc.)
A 2–4 year old system can be:
  • Faster
  • Quieter
  • Half the power draw
The reality: upgrades can pay for themselves​
If you:Save ~£150/year in electricity
  • Spend ~£200–£400 on newer used hardware
You’re often looking at:
Break-even in 1–2 years
After that, it’s just ongoing savings.
Final thought​
Running older gear isn’t wrong — especially if it’s lightly loaded.
But if you’re:
Running multiple cameras
  • Using AI continuously
  • Seeing high CPU usage
  • Or your system pulls a lot of power
…it’s worth doing the maths - buy one of those cheap energy/power monitoring plugs from somewhere like Amazon/AliExpress and run it for a few weeks/months just on your BI rig and see just how much you're using.
In a lot of cases, the “cheap” option ends up being the expensive one over time.
Reactions: iseeker and Bruce_H
