And has anyone noticed that the wall wart provided by tendelux is actually 24 volt DC...
Any suggestions how I can hide the black wire coming from the back of the IR Illuminator - concerned about animals chewing the insulation off
Was hoping they were not overdriving the diodes to gain some short term brightness.
I also have the illuminar unit talked about here. That one says DC12 volt or AC 24 volt input. I have a butt load of 24 volt Ac transformers.
Has anyone tried the tendelux unit on 24 volt ac? Will it just not work or will it brick the D110?
@Parley and @StevenFromTexas What voltage are you guys running the illuminar LPR IR at?
I was running the 12VDC power supplies. With the advent of the Dahua 5442 S3 cameras I found that I no longer needed the units. I had no problems when I did run them.
Is there a thread where you talk about the newer cams and not needing the extra IR? Link? I'll be setting up LPR soon and just want to read what some of you guys are doing.
It will almost certainly destroy it.Has anyone tried the tendelux unit on 24 volt ac? Will it just not work or will it brick the D110?
