Review-Doorbell DS-11 for use with the Dahua DB-11 video door bell.
looney2ns
16,693
24,877
Evansville, In. USA
Courtesy of @EMPIRETECANDY at Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group and EmpireTech-Andy @ Amazon.com: and EmpireTech Andy | IP Cam Talk.
We have the DS-11 door bell chime that can be used with the DB-11 door bell, reviewed here: Review-Dahua DB-11 Video Door Bell | IP Cam Talk
It can be purchased here for approx $30us shipped.
https://www.aliexpress.com/item/DS11-Chime-Built-in-Loudspeaker-Multiple-Ring-Tones-Easy-to-Install-Wi-Fi-Connection-free/32979957531.html?spm=2114.search0104.3.1.74ce69e94IHUIW&ws_ab_test=searchweb0_0,searchweb201602_8_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_10084_453_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_6,ppcSwitch_0&algo_pvid=922b9bf8-67f8-43c6-8217-dff330b8938b&algo_expid=922b9bf8-67f8-43c6-8217-dff330b8938b-0
I have received this in exchange for a fair and honest review.
Product page: DS11
User manual: https://www.dahuasecurity.com/asset/upload/product/20180709/DS11_Quick-Start-Guide_V1_0_0.pdf
Full Spec sheet: https://www.dahuasecurity.com/asset/upload/product/20180709/DS11_Datasheet_20180621.pdf
Chime
> Multiple ring tones
> Mobile application( Lechange)
> Plug & play
> Easy to install (Wi-Fi connection) "we will see about that" :)
Technical Specification Model DS11
Audio Output Built-in Loudspeaker
Ring Tone Mutiple ring tones optional( setting on APP)
Reset/WPS Button
Indicator Light
Network Wi-Fi IEEE802.11b/g/n
Voltage 90-240Vac
Yes it arrived with the incorrect power plug, but I will devise a way to power it none the less.
>Took 5 attempts to add it to the IMOU app
>First two times I pressed the door bell, it worked.
>The 3rd and 4th time pressing the door bell, it remained silent.
>I changed the ring to the actual door bell ring.
>I had power cycle both the DB11 and the DS11 to get it to work again.
>It is not loud enough. You wouldn't hear it over a normal TV show volume in another room.
>It stops ringing in 3-4 seconds.
I had the Db11 go offline 7 times while trying this, according to the IMOU app.
First attempt:
Third attempt:
Fourth Attempt
5th
I gave up.
Thank you for sharing the review.
Has the stability issues been resolved?
Would you also be able to share a photo of the reverse side with the power adapter, as I will probably need to adapt it for British/UK plug socket.
Thanks
