Courtesy of @EMPIRETECANDY , we have a new economical cam to check out.
I received this cam in exchange for an honest and fair review.
This camera will be available for $85.00 at Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group and via EmpireTech Andy
Also available on Amazon: https://www.amazon.com/dp/B07DKT2CNF?tag=ipctk-20
2MP IR Eyeball Network Camera
> 1/2.7” 2Megapixel progressive CMOS
> H.265 & H.264 dual-stream encoding
> 25/30fps@1080P(1920x1080)
> DWDR, Day/Night(ICR), 3DNR, HLC, AGC, BLC
> Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
> 2.8 mm fixed lens (3.6mm optional)
> Max IR LEDs Length 30m
> IP67, PoE
Image Sensor 1/2.7” 2Megapixel progresive CMOS
Effective Pixels 1920(H) x1080(V)
RAM/ROM 256MB/32MB
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3~1/100000s
Minimum Illumination 0.08Lux/F2.0( Color,1/3s,30IRE) 0.3Lux/F2.0( Color,1/30s,30IRE) 0Lux/F2.0(IR on)
S/N Ratio More than 50dB
IR Distance Distance up to 30m(98ft)
IR On/Off Control Auto/ Manual
IR LEDs 12
I have the 3.6mm fixed lens version, a 2.8mm version is also available.
Smart features:
https://www.dahuasecurity.com/asset/upload/product/20180323/DH-IPC-HDW1230S_Datasheet_20180202.pdf
The only portion of this cam that is metal is the ball. All the mountings are plastic.
There are no set screws for mounting. The base on the left is mounted, then the ball and it's hood snaps into the base. You can rotate the cam and the hood to the position you need. Then the white ring you place over the hood, and twist to lock it onto the base. This cam would NOT take much abuse from a vandal.
> IP67, PoE
RAM/ROM 256MB/32MB
IR LEDs 12
Smart features:
- IVS
- Tripwire
- Intrusion Box
