Hi,
I have ATT fixed wireless and port forwarding is not allowed. I use Guarding Vision on IOS for viewing cameras while away. I'm trying to be able to view the cameras on a PC. IVMS-4200 does not seem to have the ability to view Guarding Vision, only Hik-Connect. I'm not sure if I can set up both Guarding Vision and Hik Connect on the NVR. If so maybe this is the answer. Guarding Vision credentials on the IVMS-4200 Hik Connect device add do not work. Maybe I'm missing something easier.
Any ideas?
Thanks,
Doug
Any ideas?
Thanks,
Doug
