I recently moved my Windows based NVR offsite from the location where my cameras are physically located in the event someone attempts to steal the entire system.
I have 22 cameras installed at a commercial property and of course while on site on the same LAN, reviewing footage/recording of the cameras are perfect unlike when remote.
Cameras are Amcrest IP cameras: IP3M-HX2W for indoor and IPM-723B, IP2M-852W, IP4M-1026EW-28MM for outdoor.
I've opened the appropriate ports on nvr side(remote) and camera side(local) routers, upgraded router and bandwidth to 1000GBps down on nvr side and 20GBps up on the camera side.
Tried this process and both Blue Iris and Amcrest Surveillance Pro with essentially the same results.
5 cameras record remotely without interruption, skipping, or choppiness, but after the 5th camera and adding the 6th, the issues begin to take place.
The more cameras I add the more the recordings begin skipping and appear choppy.
There has been a ton of trial and error during this entire process and it seems I am at wits' end.
If there is any other information you all need to assist me with this please let me know.
