This has happened 3 times now in the last week, I haven't been able to narrow down what action I'm doing that might cause it or if Blue Iris is related or not. The computer will BSOD with a stop code "MEMORY MANAGEMENT", count to 100% and "restart" and then lock up with a black screen and not actually restart. It will sit like this indefinitely, cams offline, until I power cycle it at which point it comes back as normal.
Most recently, it happened while scrolling through a video clip via UI3 on another PC. I do not recall the circumstances of the other crashes or if I was using it at the time.
It's a HP EliteDesk 800 SFF, i4 4590, 8GB RAM. It's run fantastically for 4 years and generally hums in the mid teens for CPU % and around 50% memory utilization. It usually runs headless but I've had a monitor plugged into it since this started happening, that's how I figured out it was BSODing (didn't even know what was going on the first time my cams were offline for a full day before I realized).
Has anybody dealt with such a problem?
