Looking for a solid Dahua camera to read license plates. I will be mounting it outside on the end of a cul de sac & using Blue Iris.
All suggestions appreciated.
I will order the IPC-HFW5241E-Z12E.I have 3 of these for LPR: IPC-HFW5241E-Z12E
I only buy cameras from Andy: US $225.15 7% OFF|2019 New Arriving Model IPC HFW5241E Z12E 2MP Starlight WDR IR Bullet AI Network Camera ,free DHL shipping|Surveillance Cameras| - AliExpress
There are some tricks to getting these working well at night... but this is documented many times here.
It will be about 3 feet from the Road. I was thinking of putting a pole in the ground behind the fire hydrant.
How does this look for capturing the plates?
Also, can you share a link for the optimizations for the recommended camera?
These are my camera angles. I was under the impression that none would be as good as running a line down to the road.You will be able to get plates easily from that location. Depending on which house is yours, you could probably even place it on your house looking at that distance with the camera mentioned above. House on left you probably could, the one on the right might have too many trees in the way.
The camera mentioned above is the go to camera.
The LPR subforum threads have the set-ups of many of us here used for optimizing to get plates.
Keep in mind this camera will be for LPR duty only - you will zoom in to just about all you see is the car. Many people try to use it as an overview camera as well and then are disappointed they aren't able to read plates.
At night time, the image will be completely black due to the fast shutter speed needed to capture a plate.
Excellent. I will order one of those.That would work!
This would be your approximate zoomed in area - maybe a little tighter, but you will not know that until you get up and running - this would get the cars coming in and going out and pick them up whichever side of the street they favor turning around.
So this passive splitter is really simple - take the cable from your camera and put it into the input and then add two small cables - one going to the existing camera and the other to the new camera.
Amazon.com: LINOVISION Mini Passive 2 Port POE Switch POE Extender IEEE 802.3af/at POE Repeater Splitter Power Over Ethernet 330ft Over Cat5/6 Cable Powering 2 POE Devices Like IP Cameras Over One Cat5/6 Cable: Computers & Accessories
Amazon.com: LINOVISION Mini Passive 2 Port POE Switch POE Extender IEEE 802.3af/at POE Repeater Splitter Power Over Ethernet 330ft Over Cat5/6 Cable Powering 2 POE Devices Like IP Cameras Over One Cat5/6 Cable: Computers & Accessorieswww.amazon.com
