I've actually founded it easier to use an 8 port inline PoE injector. you can find these on ebay for about $30, it gives you the ability to run it with any switch you want at whatever speed the switch is and you are not limited to a few year old used business take out switch. you can do two of them for a load balancing/failover scenario in case one should fail or if you just need the extra power. This last go around I replaced my HP 24 port managed switch with an Asus gigabit 24port switch, fanless design so no noise and super low power draw, brand new for $115.
I can answer both actually... if those were my only two choices I would take my chances with the Kia, I will not own another Benz outside of warranty, our prior '14 ML was one of the biggest pos's I have ever had. i will have been in IT for 16 years as of June 8, I'm currently a systems engineer. I have purchased/ used/ supported many of the HP Pro-Curves ,Linksys, Cisco and Juniper switches over the years, from $300 24 port non mngd to $3k modular switches. They are designed for server racks/ server rooms, power consumption is generally high, they are noisy due to multiple fans and sometimes multiple power supplies. 95% of the features that the management console provides a common home owner or even small business user would never understand or need. it's much like a home user buying an actual used enterprise server.You get what you pay for. Would you rather have a few years old used Benz or a new Kia? I'll leave it at that.
That old switch is loud and only 10/100.....the zyxel is a superb switch...and I would take a new kia over a few year old benz any day...You get what you pay for. Would you rather have a few years old used Benz or a new Kia? I'll leave it at that.
 .  not everyone needs more than 2/3/4/5/6 ports of PoE to justify buying a dedicated PoE switch or want/ are able to house a big rackmount style switch.  In my case I have an 7 camera system but I have a total of 18 wired ports between audio/video, AP's, computers, irrigation, alarm etc, so I need the larger switch but not necessarily the PoE on all of it.
.  not everyone needs more than 2/3/4/5/6 ports of PoE to justify buying a dedicated PoE switch or want/ are able to house a big rackmount style switch.  In my case I have an 7 camera system but I have a total of 18 wired ports between audio/video, AP's, computers, irrigation, alarm etc, so I need the larger switch but not necessarily the PoE on all of it.That old switch is loud and only 10/100.....the zyxel is a superb switch...and I would take a new kia over a few year old benz any day...
Those switch are very loud..please, it would be annoying to sit in the same room with most of them. You never want to saturate a pipeline...you also have no idea what else is connected to the switch...for example it may not only be connecting cameras but another switch or pc/nas....Evidently we define loud differently. When we consider that the bandwidth we'd expect to see from a 10MP camera is about 7.2Mbps, giving it a 100Mbps pipe is more than sufficient. Giving it 1000Mbps is ridiculous in the extreme. I have 8 cams flowing through a single gigabit fiber line and it barely hits 5% utilization.
Zxyel is what I would term consumer grade / bottom of the range small business at best. Compare these boards:
Zyxel GS1900-8HP
Catalyst 3560-8
They're clearly not comparable to each other. Is Zxyel per se bad? No. Is it enterprise grade / would I allow one anywhere near my datacenter? Not by a long shot. If you can get better equipment which more than fulfills the required purpose at a cheaper price, it seems like it should be a simple choice, but I guess to each his own.
size of the board is irrelevant..size of components are irrelevant...
Also note the power consumption of that huge monstrosity is likely significantly higher than the zyxel negating any cost savings...
yes, different perspective..its idiotic to recommend server room switches for home use...thats why im pointing it out to the user...not to mention zyxel support which is helpful for the less experienced users. "consumer grade" equipment is just as reliable as anything you use...you just fell for the fluff...Yes, being a network engineer I wouldn't know anything about saturating pipelines or network design. I'm not going to argue with you. We're clearly coming at this from two different perspectives. I just do not utilize consumer grade appliances - ever. I'm well aware that they exist; I just consider them to be cheaply made garbage and I don't buy them based on that opinion.
You should recommend what you think is appropriate, and I'll do the same. The person receiving the information can make up their own mind as to which better suits their needs. More options is never a bad thing and there is no "this is the only way that things must be done" solution.
I have learned a long time ago that positions and titles are meaningless.
as mentioned already, if you can get away with that zyxel then I would probably go that route, that is a nice unit and its also gigabit. I posted regarding PoE injection simply due to the catch-all subject line of this thread. not everyone needs more than 2/3/4/5/6 ports of PoE to justify buying a dedicated PoE switch or want/ are able to house a big rackmount style switch. In my case I have an 7 camera system but I have a total of 18 wired ports between audio/video, AP's, computers, irrigation, alarm etc, so I need the larger switch but not necessarily the PoE on all of it.
do keep in mind that only 8 ports on the netgear are powered..
