Hi. I've contacted Dahua for support about this and I await their supportive response...
In the meantime I'd like to know if anyone uses the videomotion.cgi/SubscribeNotify.cgi interface for motion detection and knows how to shorten/disable the silence in the motion data stream after a ptz.start PositioABS command or a ptz.moveRelatively command is given. ptz.moveDirectly works with PtzManualMotionDetect/"Enable Manual Control Trigger", but it is too inaccurate to perform automated tours. The built-in tour function disables video motion detection so I can't use that either.
Old firmwares that don't support PtzManualMotionDetect don't silence the motion data upon PositioABS. Slightly newer firmwares have a 3-second silence (still too long for my use-case). The newest firmwares have a 10-second silence. Is there a way to compare the old and new firmwares and see what configuration causes this "feature" to be enabled?
Attached an image of the graph of the motion data of a bush swaying in the wind. The gap in the middle is the video motion data being silenced for about 10 seconds after a PositionABS command (to the same coordinates, so no actual ptz motion was performed)
