PTZ tripwire to activate tour
tomas21
Aug 12, 2014
175
24
US
Has anyone successfully setup at PTZ with tripwire enabled to activate tour when tripwire is hit?
I have tripwire working and can activate it to go to a preset PTZ location... but the tour feature doesn't activate on my NVR even thought it is enabled.
NVR4208
Firmware: 3.201.0000.1.R; buid date: 2016-04-09
SD42212T-HN
Firmware: 2.422.0001.0.R.T4.1216.3N.NR, Build Date: 2016-11-02
might have to setup the tour on the NVR, it seems like its a local feature.. SmartPSS wouldent trigger the tour I setup on the camera and made me do it again in SmartPSS..
Reactions: hmjgriffon
Hmm.. I have the tour setup on the NVR and can manually do it. I cannot invoke it automatically when tripwire is activated for some odd reason.
Made progress... but can only get it to go to the first 3 presets in the tour then it stops on the 3rd one... any setting that would prevent it from going to the remaining 5 presets? Like some timer setting for IVS PTZ activation
So no matter what presets I select for the tour... when the IVS tripwire is activated the tour only does the first 3 presets I chose and then stops. Anyone aware of any settings that would prevent the presets from going past 3 roughly 15 seconds?
