Has anyone come across a way to mount a PTZ ( Dahua SD59230UN-HNI ) close to the ceiling/soffit?
(outdoor ocean environment)
I've been looking for a while and even asked Andy - Seems that there is only one option for a Dahua ceiling mount that is the PFA110+PFB300C (see diagram)
My challenge is that it is too long.
The PTZ is about one foot tall and the shaft on the (PFB300C) mount is over 9" then you have the PFA111 and in my case I will also need a junction box to connect the wires. That's about 2 feet tall.
Mounting options:
Mount Guide - Dahua Wiki
Dahua SD59230UN-HNI
PFB300C
PFA110
There are some manufacturers offering a short option (ie. Sunba 2 cm)
Do you know of another manufactures mount that will work/fit? (Dahua SD59230UN-HNI)
Or a way to modify?
Thanks
Mounting options:
Dahua SD59230UN-HNI
PFB300C
PFA110
Or a way to modify?
Thanks
