- Dec 8, 2017
- 5
- 0
Hello,
I'm currently facing a wierd problem about Dahua system. First, the current configuration is this:
NVR: 1x NVR5432-4KS2
IP Camera: 16x IPC-HF-W1300SP
PoE Switch: 1x Planet GSW-2620VHP
Dedicated PC with only Smart PSS installed and a few other miscellaneous programs.
The problem: Sometimes Smart PSS display the message "Device Offline" on all 16 cameras display's on a local PC monitor. The wierd thing is that the NVR has a local internet connection with PC and the whole video system is under a UPS. I can tell that the main power still worked when the "Device Offline" showed up, so it's not about UPS not having enough power.
Also the NVR is set to have a static IP so it didn't lose connection with the PC. The system is also connected to internet using a P2P connection. The P2P function works great both on PC (other PC, around 400KM away from the place where the video system is located) and on mobile app. Only the local PC lose conection with NVR. So I want to ask what is the problem, or what should i change to make the system work without problems.
I need to mention that changing NVR's IP from static to DHCP is out the question because i need to have a local connection between the PC and NVR.
Thank you
Thank you
