I bought DS918+ and will be using it mainly as NVR unit. I should receive it tomorrow. I tried different dedicated NVRs and they work fine except the phone and PC applications. They leave so much to desire. That’s why I decided to go the Synology DS route.
This Synology DiskStation comes with two ethernet ports. I was thinking, can I connect my POE switch to the Synology DiskStation via one of the ethernet ports and then the Synology to the router?
The reason why I’m suggesting this setup instead of connecting the POE switch to the router and then the Synology server to the router, is because I don’t want the video to roam in the router and then into the Synology DiskStation. I want the Synology DiskStation to receive the video signal from the POE switch directly. Is that possible?
