Hi Guys
I'm just about to purchase a new camera and it requires POE 12v 1.5amp input ..can anyone recommend the cheapest POE injector I can get away with without affecting reliably ..I only need one port POE'd so I definitely don't need a whole switch ..I've found a 12v 1amp unit but does anyone know if this model camera is happy with only 1amp ? The IR will be in use.
it says max wattage on Dahau website 8w with IR on, so if i got a 12v x 1amp that should be 12w using P = Amp x Volts and yet the Dahau website says it needs 12v x 1.5amps
Just looking for clarification as the Dahau website seems to contradict itself
