Hello,
I’m not sure if I’m posting this to the right sub forum, but since I think I might have a hardware configuration issue, I’ll post here first. If I’m in the wrong forum, my apologies. I recently updated an older POE Dahua NVR to a newer model, DH-NVR2108HS-8P-I2. I used all the same Dahua POE cameras as what was in the old Dahua NVR setup. All cameras worked fine previously. After getting everything transferred over to new NVR, I’ve run into a peculiar situation. Every Tuesday morning (2AM), one of my Dahua POE cameras loses connectivity to the new NVR. The camera model is DH-SD29204T-GN. I use the POE switch functionality built into the NVR, and all cameras utilize the internal NVR DHCP setup (10.x.x.x address space). In order to resolve this issue, I have to log into the NVR console, delete the old instance of the camera, and add the camera’s new IP address (it always changes) back into the NVR camera profile. Once I input the camera’s (non default) password to its configuration, the camera comes back online right away. After I reset the camera in this way, it works fine until the following Tuesday at 2AM and I have to repeat the process all over again.
I disabled the NVR’s weekly auto reboot function (which defaulted to rebooting every Tuesday morning at 2AM) thinking that might solve the issue, but the problem still persists. I did some searching on this forum and found a reference to changing camera stream settings from CBR to VBR as a way to potentially solve issues that have a similar appearance. The offending camera’s setting was set to CBR, so I changed it to a VBR setting. Those changes didn’t resolve the issue.
The NVR is running code version 4.002.0000000.0, Build date 2021-07-09, which appears to be the latest code for this device. Ironically, I have a second Dahua POE camera that loses connectivity (with the same fix) as well, but for some reason that one only loses connectivity once every 3-4 weeks.
If anyone has any suggestions, I’d be grateful for the help!
Thanks.
Thanks.
