aristobrat
- Dec 5, 2016
- 2,979
- 3,180
If you wanted a setup/configuration experience "well planned out in the design stages" for consumers, then buy a consumer-grade camera designed for the home environment. Nest, Arlo, Ring, ... there are a million different brands that are designed for the home environment where having DHCP around is pretty much a given.if a manual is required to use a network device then the setup/configuration was not well planned out in the design stages..
Professional-grade cameras are designed to be installed in environments that may not have DHCP servers. In additional, contractors hired to install cameras in these types of environments are never guaranteed to have access to the client's routers and/or DHCP servers (if they happen to exist). So for scenarios like this, the camera coming out of the box with a KNOWN static IP address (vs DHCP) is an aspect that was well planned out in the design stage.
