Hey everyone,
Please could you assist in me getting the best image quality. I have 7 x 5MP Colorvu cameras. I find that image is quality is poor. I have tried all sorts of settings but find that images are blurry. I live on a street with cars coming up and down as well as people passing by.
Here are my settings, I am really close to changing manufacturers as I just cannot seem to get it right, I have spent a lot of time researching, I have had the bit rate higher, lower, I have had the video quality at medium and also bitrate type set to constant as well as H264 & H265 and also with the + set on both.
It seems the theme is a constant bitrate but what should the bit rate be? HIK vision said it should be really low, much lower than their calculator told me and much lower than what it reccomendes as a bitrate range on the front end.
I have WDR set on the cameras themselves as this seems to be the best I can get it, my settings are below.
Any help gratefully received.
Main Stream Normal:
Main Stream Event:
Sub-stream:
Image settings:
Main Stream Normal:
Main Stream Event:
Sub-stream:
Image settings:
