Hi,
I am currently running BI 5 off the following;
HP Elitedesk 800 G2 SFF
So reason for my post is - I am going to have in a few weeks some cat6 running through the house as we are doing a refurb and figured it would be a good time to do so. Everything will be centralised in a downstairs cupboard (3200m x 1100mm) and ideally I'd like to get it all in a data cabinet - so patch panel, a switch (+ a PoE switch), router, and then the BI server/box.
First question is ... can I just stick the Elitedesk on a rack mount shelf in the cab ? I'm a bit of a noob at this sort of stuff and I'm not really sure how much U in the rack it will take up (and how much it might need for clearance for airflow etc). Or, at this point of install of stuff is it worth spending a bit more money on getting something like a 2U case, transferring over my 2 HDDs, getting a new motherboard (micro ATX?) and processor to save some space within the cabinet? I obviously wouldn't want to spend £££ only to save a bit of space in the rack as I could just get a bigger cabinet, but just wondering if the PC needs an upgrade anyway whether it might be worth doing it all now than say in a years time or in the short term.
Second question was about the switches ... again might be a silly question but is it better to have say, a single 24 port switch, and a PoE injector for each camera off that single switch (or a single PoE switch for all cams), or is it better to have a smaller main switch (5 port) connected to the router, and say another small switch (5 port or so) for each room/camera area so each room has it's own switch ? or, doesn't it really matter that much?
Thanks in advance
- I5-6500 @ 3.20Ghz 4 Core
 - 4GB DDR4 RAM 2133MHz
 - OS HDD - Western Digital 500GB (WD5000AZLX-60K2TA0)
 - Cam recordings HDD - Seagate Skyhawk
Thanks in advance
