- Nov 30, 2017
- 187
- 96
I am thinking of assembling a system together to run blue iris. I looked at many refurb SFF pc's like dell optiplex, in the end, I prefer something with relatively current specs. Most ($300 range) refurbs are 4 core i7's.
To that end, I am considering a six core i5, 16GB RAM and an SSD + WD purple drive for video. I plan to deploy at least six (possibly 8) 4K cams. Based on the formula in the wiki, about 250MP's are generated by two 4K cams @ 15FPS, I'll need 750MP's, for six 4K cams. That translates to getting at least a six core CPU for those six 4K cams
I won't need a video card because only integrated intel video is needed for Blue Iris. Lastly, I have a windows 10 pro x64 license already. So, the load on the power supply will be from mobo/RAM/CPU Fan/SSD/WD Purple. NIC and Video are part of mobo.
Based on the above, I have two questions:
1) since the focus is on cores, does it matter if I get an i5 versus an i7 CPU ?
2) I found a low profile case that comes integrated with a 300 watt power supply. It that adequate for this build or do I need to get a beefier standard power supply (and a case that would support it) ?
thank you !
thank you !
