I just received an optiplex 7040 that I ordered from Ebay. See attached description. I was under the impression the SSD was going to be a 2.5in in a caddy and there was going to be an optical drive as well. As you can see from the pic there is neither. The SSD is an M.2 stick. I would be fine with that except now I'm not sure how I'm going to add a second WD purple HD for my camera footage. There does not appear to be any 15 pin sata power connectors on the motherboard. The only SATA power I can find is a 6 pin connector. Is there a 6 pin to SATA power cable? What would be the best way to do this? The seller says no returns, but it seems the listing wasn't entirely accurate. Any assistance would be appreciated. Thanks
