Hey everyone,
I recently picked up a new Hikvision DS-7616MXI-I2/16P/S NVR. Ive got 7 Hikvision cameras hooked directly up to the NVR using Plug and Play and they are working fine. I have a single Pakedge camera (rebranded Lilin) hooked to the NVR POE but I can seem to get it to work. In the NVR Camera Configuration I did a Manual record using ONVIF with the 192.168.254.6 address. I verfied on the Pakedge camera that ONVIF is enabled and I used the ONVIF tool to verify it was working without issue. The error message the NVR is giving is
I double checked that the IP Camera is set for h.264 encoding, but Im not sure what else might be the issue here. The Pakedge camera is a 4MP CK-CAM-BU8442Z.
| D5 | IPCamera 05 | 192.168.254.6 | 1 | 80 | Strong | Offline(Stream type from the IP camera is not supported) | ONVIF |
