Hi, I notice on the live feed from my DH-SD49225T PTZ that it can be a bit jittery on large scenes with fast moving objects. Seems to be less so when the camera is zoomed in on a smaller area.
Recorded playback seems to be smooth and so does live view on mobile devices.
The DH-SD49225T IP PTZ in plugged into an XVR with multiple HDCVI cameras connected.
Bit rate is set at 5120kbps (max incoming stream allowed per channel for IP cameras on my Dahua XVR) on CBR at max frame rate 25FPS (pal region).
I ran a ping test for about 3 minutes (laptop plugged in with network cable direct into switch). This is the result:
- Is it normal for any packet loss to occur when pinging an IP camera?
- Would this packet loss mean there is an issue, or is it acceptable?
- And are the ping speed results fast enough?
