So I know the controversy surrounding P2P connections, but I have a questions about them.  Does anyone know how direct of a connection it attempts to create between your device and your camera?  Say you are on the same subnet as the camera with your phone.  When you initiate a P2P connection will it be smart enough to recognize that and make the connection between phone and camera using your local network only?  Or does it still route out to the internet, and then back into your network?
Currently when I setup customers with a P2P connection, I put the device on their phone twice. One with the local IP address to connect to when they are on the same subnet, and one with P2P for when they are remote. I do this because our rural internet is very poor, at best you can count on 1mbps upload speed, and lots of people have data caps as well. To have a P2P connection always routing out to the internet and back into your network while you are on the same subnet, you would saturate your upload connection, and burn through your data cap in no time.
Anyone know for sure how it works? Thanks,
