Hi guys,
I have been reading the forum for a while now and I am very impressed by the great information, though it can be somewhat overwhelming.
I am looking for a PTZ camera to be used for monitoring farmland here in Florida. We need PTZ, as we need to shift our focus to different areas at different times.
The camera will be out in the field completely exposed to the elements.
I was thinking of one of the following three models:
SD6CE230U-HNI, SD59225U-HNI or SD49225T-HN.
The most important thing for us is that the camera be very reliable in terms of handling the weather, as well as from a firmware point of view, since it will not be convenient to get out to the field to fiddle with it. We will not need any of the AI features. Obviously, we would like the cheapest model that would satisfy our needs.
In particular, I have the following questions:
1. The SD6CE230U-HNI is rated IP67, while the other two IP66. I know what these specs mean, and on paper IP66 should be good enough, but I don't know if that is true in the real world, and would love feedback on that.
2. The SD59225U-HNI is from the pro series, and the SD49225T-HN is from the lite series and much cheaper, but otherwise with almost identical specs. Except for less AI capabilities of the lite series, and the other minor spec differences, is there any major difference between the two? In particular, the SD49225T-HN is much lighter, suggesting a less robust construction, but I may be wrong. Any feedback on the important differences between the two cameras would be great.
3. I have tried to follow the thread of the SD59225U-HNI but it is impossible being over 100 pages long. I could not figure out if this camera is reliable enough (firmware wise) to simply install and forget. Clarifying this point would be great.
Thanks in advance!
Thanks in advance!
