Hi Arisobrat,
I am not saying that my camera is dead in the water - for now, I've added my primary and secondary RTSP stream URL's into NxWitness and my cameras are functioning. BUT, the Dahua in-camera analytics capabilities will not work with NxWitness 4.0 unless the camera properly reports its streams and other capabilities and properly responds to the Onvif API requests.
The issue is that the XML data returned in the massive 16kb response to the following request is "not proper" - I am not an expert to understand why both ODM and NxWitness both don't like it. I captured this with Wireshark (NOTE: I masked my security details below
and formatted it for readability):
/dan
Code:
POST /onvif/media_service HTTP/1.1
Content-Type: application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/media/wsdl/GetProfiles"
Host: 192.168.1.140
Content-Length: 906
Accept-Encoding: gzip, deflate
Connection: Close
<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope">
<s:Header>
<Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<UsernameToken><Username>admin</Username>
<Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">XXXXXXXXXXXXXX/XXXX/X/XXXXX=</Password>
<Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">AAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==</Nonce>
<Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">2019-09-13T15:01:03.931Z</Created>
</UsernameToken>
</Security>
</s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GetProfiles xmlns="http://www.onvif.org/ver10/media/wsdl"/></s:Body></s:Envelope>
HTTP/1.1 200 OK
Connection: close
Content-Length: 16731
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tt="http://www.onvif.org/ver10/schema">
<s:Header/>
<s:Body>
<trt:GetProfilesResponse>
<trt:Profiles token="MediaProfile000" fixed="true">
<tt:Name>MediaProfile_Channel1_MainStream</tt:Name>
<tt:VideoSourceConfiguration token="000">
<tt:Name>VideoSourceConfig_Channel1</tt:Name>
<tt:UseCount>3</tt:UseCount>
<tt:SourceToken>000</tt:SourceToken>
<tt:Bounds x="0" y="0" width="2048" height="1536"/>
</tt:VideoSourceConfiguration>
<tt:AudioSourceConfiguration token="000">
<tt:Name>AudioSourceConfig_Channel1</tt:Name>
</tt:AudioSourceConfiguration>
<tt:VideoEncoderConfiguration token="000">
<tt:Name>VideoEncoderConfig_Channel1_MainStream</tt:Name>
<tt:UseCount>1</tt:UseCount>
<tt:Encoding>H264</tt:Encoding>
<tt:Resolution>
<tt:Width>1920</tt:Width>
<tt:Height>1080</tt:Height>
</tt:Resolution>
<tt:Quality>3.000000</tt:Quality>
<tt:RateControl>
<tt:FrameRateLimit>60</tt:FrameRateLimit>
<tt:EncodingInterval>1</tt:EncodingInterval>
<tt:BitrateLimit>7842</tt:BitrateLimit>
</tt:RateControl>
<tt:H264>
<tt:GovLength>120</tt:GovLength>
<tt:H264Profile>Main</tt:H264Profile>
</tt:H264>
<tt:Multicast>
<tt:Address>
<tt:Type>IPv4</tt:Type>
<tt:IPv4Address>224.1.0.0</tt:IPv4Address>
</tt:Address>
<tt:Port>40000</tt:Port>
<tt:TTL>64</tt:TTL>
<tt:AutoStart>false</tt:AutoStart>
</tt:Multicast>
<tt:SessionTimeout>PT60S</tt:SessionTimeout>
</tt:VideoEncoderConfiguration>
<tt:AudioEncoderConfiguration token="000">
<tt:Name>AudioEncoderConfig_Channel1_MainStream</tt:Name>
<tt:UseCount>2</tt:UseCount>
<tt:Encoding>AAC</tt:Encoding>
<tt:Bitrate>128</tt:Bitrate>
<tt:SampleRate>32</tt:SampleRate>
<tt:Multicast>
<tt:Address>
</tt:Address>
<tt:Port>40002</tt:Port>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
<tt:SessionTimeout>PT00H01M00S</tt:SessionTimeout>
</tt:AudioEncoderConfiguration>
<tt:VideoAnalyticsConfiguration token="000">
<tt:Name>AnalyticsConfig_Channel1</tt:Name>
<tt:AnalyticsEngineConfiguration>
<tt:AnalyticsModule Name="MyCellMotion" Type="tt:CellMotionEngine">
<tt:Parameters>
<tt:SimpleItem Name="Sensitivity" Value="60"/>
<tt:ElementItem Name="Layout">
<tt:CellLayout Columns="22" Rows="18">
<tt:Transformation>
<tt:Translate x="-1.000000" y="-1.000000"/>
<tt:Scale x="0.006250" y="0.008340"/>
</tt:Transformation>
</tt:CellLayout>
</tt:ElementItem>
</tt:Parameters>
</tt:AnalyticsModule>
<tt:AnalyticsModule Name="MyTamper" Type="tt:TamperEngine">
<tt:Parameters>
<tt:SimpleItem Name="Sensitivity" Value="48"/>
<tt:ElementItem Name="Field">
<tt:PolygonConfiguration>
<tt:Polygon>
<tt:Point x="0" y="240"/>
<tt:Point x="0" y="0"/>
<tt:Point x="320" y="0"/>
<tt:Point x="320" y="240"/>
</tt:Polygon>
</tt:PolygonConfiguration>
</tt:ElementItem>
<tt:ElementItem Name="Transformation">
<tt:Transformation>
</tt:ElementItem>
</tt:Parameters>
</tt:AnalyticsEngineConfiguration>
<tt:RuleEngineConfiguration>
<tt:Rule Name="Region1" Type="tt:CellMotionDetector">
<tt:Parameters>
<tt:SimpleItem Name="MinCount" Value="19"/>
<tt:SimpleItem Name="AlarmOnDelay" Value="1000"/>
<tt:SimpleItem Name="AlarmOffDelay" Value="1000"/>
<tt:SimpleItem Name="ActiveCells" Value="0P8A8A=="/>
</tt:Parameters>
</tt:Rule>
<tt:Rule Name="MyTamperDetector" Type="tt:TamperDetector">
<tt:Parameters>
<tt:Polygon>
</tt:Polygon>
</tt:ElementItem>
</tt:Parameters>
</tt:Rule>
</tt:RuleEngineConfiguration>
</tt:VideoAnalyticsConfiguration>
<tt:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0">
<tt:Name>PTZConfig_Channel1</tt:Name>
<tt:UseCount>111</tt:UseCount>
<tt:NodeToken>000</tt:NodeToken>
<tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace>
<tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace>
<tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace>
<tt:DefaultPTZSpeed>
<tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.800000"/>
</tt:DefaultPTZSpeed>
<tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout>
<tt:ZoomLimits>
<tt:Range>
<tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI>
<tt:XRange>
<tt:Min>0.000000</tt:Min>
<tt:Max>1.000000</tt:Max>
</tt:XRange>
</tt:Range>
</tt:ZoomLimits>
</tt:PTZConfiguration>
<tt:MetadataConfiguration token="000" CompressionType="">
<tt:Name>MetadataConfig_Channel1</tt:Name>
<tt:PTZStatus>
<tt:Status>false</tt:Status>
<tt:Position>false</tt:Position>
</tt:PTZStatus>
<tt:Events>
<tt:Filter>
<wsnt:TopicExpression xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics" Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:TopicExpression>
</tt:Filter>
</tt:Events>
<tt:Analytics>true</tt:Analytics>
<tt:Multicast>
<tt:Address>
<tt:IPv4Address>224.2.0.0</tt:IPv4Address>
</tt:Address>
<tt:Port>40020</tt:Port>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
</tt:MetadataConfiguration>
</trt:Profiles>
<trt:Profiles token="MediaProfile001" fixed="true">
<tt:Name>MediaProfile_Channel1_SubStream1</tt:Name>
<tt:VideoEncoderConfiguration token="001">
<tt:Name>VideoEncoderConfig_Channel1_SubStream1</tt:Name>
<tt:Resolution>
<tt:Width>640</tt:Width>
<tt:Height>480</tt:Height>
</tt:Resolution>
<tt:Quality>6.000000</tt:Quality>
<tt:RateControl>
<tt:FrameRateLimit>7</tt:FrameRateLimit>
<tt:BitrateLimit>240</tt:BitrateLimit>
</tt:RateControl>
<tt:H264>
<tt:GovLength>20</tt:GovLength>
</tt:H264>
<tt:Multicast>
<tt:Address>
<tt:IPv4Address>224.1.0.1</tt:IPv4Address>
</tt:Address>
<tt:Port>40008</tt:Port>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
<tt:AudioEncoderConfiguration token="001">
<tt:Name>AudioEncoderConfig_Channel1_SubStream1</tt:Name>
<tt:Encoding>G711</tt:Encoding>
<tt:Bitrate>32</tt:Bitrate>
<tt:SampleRate>8</tt:SampleRate>
<tt:Multicast>
<tt:Address>
</tt:Address>
<tt:Port>40010</tt:Port>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
<tt:Parameters>
<tt:Transformation>
</tt:CellLayout>
</tt:ElementItem>
</tt:Parameters>
<tt:Parameters>
<tt:Polygon>
</tt:Polygon>
</tt:ElementItem>
<tt:Transformation>
</tt:ElementItem>
</tt:Parameters>
<tt:Parameters>
</tt:Parameters>
</tt:Rule>
<tt:Parameters>
<tt:Polygon>
</tt:Polygon>
</tt:ElementItem>
</tt:Parameters>
</tt:Rule>
<tt:ZoomLimits>
<tt:Range>
<tt:XRange>
</tt:XRange>
</tt:Range>
</tt:ZoomLimits>
<tt:PTZStatus>
</tt:PTZStatus>
<tt:Events>
<tt:Filter>
</tt:Filter>
</tt:Events>
<tt:Multicast>
<tt:Address>
</tt:Address>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
</trt:Profiles>
<trt:Profiles token="MediaProfile002" fixed="true">
<tt:Name>MediaProfile_Channel1_SubStream2</tt:Name>
<tt:VideoEncoderConfiguration token="002">
<tt:Name>VideoEncoderConfig_Channel1_SubStream2</tt:Name>
<tt:Resolution>
<tt:Width>704</tt:Width>
</tt:Resolution>
<tt:RateControl>
<tt:BitrateLimit>256</tt:BitrateLimit>
</tt:RateControl>
<tt:H264>
</tt:H264>
<tt:Multicast>
<tt:Address>
<tt:IPv4Address>224.1.0.2</tt:IPv4Address>
</tt:Address>
<tt:Port>40016</tt:Port>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
<tt:Multicast>
<tt:Address>
</tt:Address>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
<tt:Parameters>
<tt:Transformation>
</tt:CellLayout>
</tt:ElementItem>
</tt:Parameters>
<tt:Parameters>
<tt:Polygon>
</tt:Polygon>
</tt:ElementItem>
<tt:Transformation>
</tt:ElementItem>
</tt:Parameters>
<tt:Parameters>
</tt:Parameters>
</tt:Rule>
<tt:Parameters>
<tt:Polygon>
</tt:Polygon>
</tt:ElementItem>
</tt:Parameters>
</tt:Rule>
<tt:ZoomLimits>
<tt:Range>
<tt:XRange>
</tt:XRange>
</tt:Range>
</tt:ZoomLimits>
<tt:PTZStatus>
</tt:PTZStatus>
<tt:Events>
<tt:Filter>
</tt:Filter>
</tt:Events>
<tt:Multicast>
<tt:Address>
</tt:Address>
<tt:TTL>64</tt:TTL>
</tt:Multicast>
</trt:Profiles>
</trt:GetProfilesResponse>
</s:Body>
</s:Envelope>
/dan
