Hallo Guys,
I have a problem with my IPC-HDW5442TM-AS 2.8 lens. I configured to save all alarm records on my NAS via smb. Saving works without problems. I can see the files and play them with the VLC player.
But if I want to playback them on Smart PSS there is always the message "Channel IPC has no record!". Everything else is working on Smart PSS for this camera.
I have two IPC-HDW5442TM-AS 3.6 lens cameras and they are configured the same. Both are working with Smart PSS. They store the records on the same NAS.
I checked the tcp packages with Wireshark and I can see that the camera is returning an error when Smart PSS is asking if there are records:
One information is missing: Both 3.6 lens (working) are running on firmware V2.800.0000000.0.R. The 2.8 (not working) camera is running V2.800.0000000.1.R.
Should I try to downgrade the 2.8 lens camera? Is this possible? Any tipps?
Thank you,
nitro
		JSON:
	{"error":
        "code":2 85409284,
        "message":""
    "id":224535,
    "result":false,
    "session":2147483619
}One information is missing: Both 3.6 lens (working) are running on firmware V2.800.0000000.0.R. The 2.8 (not working) camera is running V2.800.0000000.1.R.
Thank you,
nitro
