I International784 Getting the hang of it Apr 7, 2023 305 98 USA Apr 29, 2023 #1 If I use this NVR with my ptz, am I able to record continuously BUT, still have the ability to look at events that are triggered by a rule in a given preset? If I get this, I’ll buy Blue Iris as well to help manage it.
wittaj IPCT Contributor Apr 28, 2019 33,915 64,703 USA Apr 29, 2023 #2 Yes you can. But why buy an NVR and Blue Iris? They are each a stand alone VMS (Video Management System) that are independent of one another. Simply pick one. Blue Iris won't manage the NVR or talk to it or vice versa. Now having used NVRs and now BI, I feel BI is way more robust. Do a search here for BI versus an NVR and look at the pros and cons of each and then pick the one best for you. Reactions: JDreaming and International784
I International784 Getting the hang of it Apr 7, 2023 305 98 USA Apr 29, 2023 #3 I did just that just now. I ASSumed I wanted a NVR running 24/7. Rolling with BI.
I International784 Getting the hang of it Apr 7, 2023 305 98 USA Apr 29, 2023 #4 Is there anything different about buying from IPcam vs directly from BI?
