rufunky Getting comfortable Dec 2, 2015 719 251 Oct 25, 2017 #1 Is the only difference between the NVR4108-8P-4KS2 and the NVR4116HS-8P-4KS2 the number of channels it can display?
mat200 IPCT Contributor Jan 17, 2017 18,545 31,075 Oct 25, 2017 #2 rufunky said: Is the only difference between the NVR4108-8P-4KS2 and the NVR4116HS-8P-4KS2 the number of channels it can display? Click to expand... Hi Rufunky, I believe so. I would also consider the 5216 model.
