NVR -vs_ Blue Iris
Matt_A
Nov 22, 2022
23
6
SE US
Hi all,
Got a poe Duhua NVR and a standalone machine with Blue Iris and POE switches. If you were going to select one system base, which would you choose? Why?
There are tons of threads already discussing this..
NVR versus Blue Iris
Here are a few select ones:
NVR vs BlueIris. Which NVR for Dahua cams or build NVR? Power consumption?
So I'm likely getting Dahua cameras. If I was to use a NVR, how much of a power difference is that over blue Iris machine? Parts I have to make a blueiris machine is i3 8100, 12GB, 120 ssd, 2x 3TB WD Reds To run blue Iris on above, will it be significantly more power draw over NVR? (Assume 4...
Comparison NVR System
Hello is there somewhere a good comparison of NVR System. Because of that my Dahua NVR doesn't boot anymore after firmware up and downgrade, i am testing the Reolink NVR. But the Reolink NVR, has too problems, with browser, and i can't get the Dahua Door Cam working with. Is there somewhere...
Hello ~ & NVR options.
Hi everyone, I am new here an have couple of questions regarding NVR options. I started looking into a four cameras setup for my home, I am happy either either dahua starlight or hikvision darkfighter. The most important to me is features. As I don't want to go down the path that the NVR...
Recommendations for home video security system
(I apologize if this isn't the correct forum for this question.) I'm looking for recommendations for a home surveillance system using 4 or 5 cameras, mostly for outside use. I started to assemble a system using a PC with Zoneminder and a couple of different wifi cameras (Amcrest 841 and a...
Reactions: Matt_A
I am currently facing this question too. I did check out this dahua recorder spec sheet: NVR2108HS-8P-I2
It should be sufficient to drive 4-5 4MP cameras while I try to figure out if I would prefer BI.
Also looked at NVR4108HS-8P-4KS2/L. Not sure what I need...
Is there any functionality I would lose? Like camera settings for exposure, LED, whatever? Any serious objection?
Is there any reason why I should not be able to resell it, in case I decide for BI in the long run? I realize, I would have to buy a POI injector switch if I replace it.
The spec sheet calls for 10W for the recorder, without camera poe or HDD. I can't beat that with my PC, I won't even get close.
