Hi,
I am going to set up a video surveillance system for my parents and wanted to ask if this setup is ok or if someone has any better recommendations.
It is planned to use the 3 current wifi cameras we already have ( BlitzWolf® BW-SIC1 IP67 720P HD Wireless Security Surveillance AP ONVIF Outdoor Wifi IP Camera ) and later add 2 or 3 additional cameras (this time then via PoE instead of wifi). Therefore I thought about an 8ch NVR. There should be an easy to use Android-App for live viewing as well as reviewing recorded footage. I am planning on adding a 1-2TB harddisk and the NVR should only record when detecting motion.
Because we don't really have much budget for this, so I can't really spend more then 120€ (145$) for an NVR.
I found this NVR from Dahua which even has IVS, H.265 and PoE: Dahua 4K NVR NVR4104 P 4KS2 4CH with 4 POE NVR4108 P 4KS2 8ch with 4PoE ports replace NVR4104 P NVR4108 P Network Video Recorder-in Surveillance Video Recorder from Security & Protection on Aliexpress.com | Alibaba Group
https://www.aliexpress.com/item/Dah...i-1U-4-PoE-Ports-HDMI-Network/2014316022.html
At a later time I probably would add the following 2 cameras from Dahua and connect them via PoE: Original Dahua IPC HDW4431C A replace IPC HDW4421C A 4MP Network IP Camera IR POE CCTV Mic Built in dome DH IPC HDW4431C A-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
Would you recommend this NVR or do you have any better recommendation?
Is Dahua ok or should I look for example to Hikvision?
Apart from an English firmware, is there anything special to consider when buying a dahua product on Aliexpress?
Thank you in advance.
