Ya, I'm guessing now its the cable.If the cable is bad, and theres no connection to the camera, then the ladder is your only option on the 5442
As to the others, same problem, but I cant be assured they'll adopt the NVR password
The thing that doesnt make sense is you say they were all reachable (green indicator I assume?) on the bench. So they all had the correct password... and they're all getting an assigned IP from the NVR. So the red indicator would tell me the NVR doesnt recognize their passwords, or some problem with the cable...
So if you havent changed any passwords and they worked before, well....
The pencil icon allows you to tell the NVR the cameras login details. IT DOESNT CHANGE ANYTHING, it simply gives the NVR the correct creds of the camera so it knows how to communicate with them, so unless you changed anything here, this shouldnt apply
Appreciate your help with this, nice to know the pencil can help change creds. I'lll report back tomorrow once I get everything up and at least know one of my cameras is working with the new NVR
