I have a mix of cameras and concerned about which NVR to get from which vendor, as I expect problems when trying to connect cameras brand different than the NVR brand.
I actually need to connect these 6 POE cams to a new NVR, 2 x Dahua (SD49225XA-HNR, Z12E ), 1xUniview PTZ 5MP, 3 x HikVision (DS-2DE3A400BW-DE, DS-2CD2347G2-LSU/SL)
Shall I consider BlueIris (or similar) and dedicate a PC for it and use client apps to access from also MAC-?, iOS devices, or take the risk with choosing a dedicated NVR (preferred option providing client apps are solid to use or at least from web even on mac OS)?
Tried the SD card approach 256Gb per cam, nerve recking when trying to access from non-PC browsers these camera web UI's as nothing works, as they need Windows or still ancient IE.
. Why IE from such vendors in 2022 is beyond me..
Have the option for Synology Surveillance Station, should I even attempt that route?
Any tips/advise appreciated for which NVR model to consider.
Thanks.
Thanks.
