HI Guys,
I use Milestone in a Virtual Machine on my server to to reliably recording my 3MP and 5MP cams - am mix of ONVIF compliant cams HIK, Longsee, Axis and SMTSEC. These cams have fixed IP's on their own subnet.
I want a separate (low power, always on) device that I can use to display the cam live streams on my TV (over HDMI). I am considering a DS-7608N.
Can someone tell me :
1) I assume I can simply connect a (single) lan cable (on that same subnet) to one of the camera ports on the dvr? I assume it's just basically a poe swirtch - not dedicated separate ports.
2) The HIK's are genuine english firmware cams...Are the cams likely to work with the "hacked" firmware NVR?
3) I assume there is not a remote
How would you suggest I change cam's that are displayed (in full screen) on the TV remotely.
Thanks!
Thanks!
