Nvr ds-7608ni-se / p
maspirault
Jun 22, 2015
15
1
Hello,
I bought an NVR hhikvision DS-7608NI-SE/P believing having 8 channel . But I have only 4 POE ports on the back. I asked if i put a POE switch I was able to have 8 camera. In the configuration of NVR I see nothing that can make me install eight cameras.
Thank you
Yes but i only see four channel, and in Device information it says Number of channel : 4.
I dont receive all my camera i will be able to do more test next week or the other
Mike is correct. The 4 PoE channels are pre-configured and fixed in the configuration, and represent the PoE ports on the back panel. The remaining 4 come from the LAN and are for you to add up to the maximum of 8.
If you want to put your mind at rest - try with the 'Add' button adding a dummy entry using an unused IP address on your LAN.
The NVR will complain the camera is off-line or does not exist, but then you will have 5 entries.
