NVR cooling
pinecone
Dec 21, 2015
53
3
My Hikvision NVR is in a location where it can conveniently be ran with the cover off. Would this provide better cooling? Or is the case designed for the fan to pull/push air more efficiently?
Also another possibility would be case off with a 140mm computer fan blowing across the board.
Hi @pinecone
The system is designed to have airflow over it to remove heat. So if you're removing the case, you'll want to ensure proper airflow is still occurring.
