If I enable motion detection for the channel on the NVR I can see the yellow MD recording during playback using SmartPSS. As far as I understand in this setting it is the NVR doing the Motion Detection.Make sure on the playback timeline you are checking (enabling) yellow motion detection playback. If playback is at 24hrs sometimes you can miss small yellow motion events on the timeline. Try 2hr or 1hr zoom and when you locate something, go for 30 min for a better event zoom size.
Setting everything in the NVR is really tweaking the camera too. The nvr isn't 'isolated' from the camera. The nvr and camera are synced to push changes you make on either side. But as been pointed out, it's usually better to enable motion detection and IVS and regions/rules in the camera. Once you save it and look back in the nvr it should mirror the settings. Sometimes the sync to camera can get screwed up if you do it all in the nvr. I haven't really had that problem in a long while but it can happen- mostly with exposure and encoding settings. Usually all is well with motion settings though.
In order to let the camera to do the MD I disable motion detection on one the NVR for the channel. Now my question is in this scenario what is the setting that can cause the NVR start recording when the camera detects motion.?
My settings at the camera side are OK (I think) when I modify something using the web interface I can see the changes from the SmartPSS side as well, the communication between the NVR and the cameras looks OK.
Can you point me to the settings that I should be changing?
