NTP not working
dohat leku
May 19, 2018
354
36
usa
guys - my cameras are 3 mins ahead of my PC (which has the accurate time) and this occurred i just 4 months. Has anybody got NTP to work? I'm using the default clock.isc.org and can confirm port 123 is open to all cameras. I'd rather use NTP permanently as it's far more accurate than sync to pc and I can set and forget
Thx
Is that really necessary though? I have network devices at home and they all point to public ntp servers and work great
Open inbound from the internet?
Not required, and a little risky, when configuring access to an NTP server out on the internet.
In any case, the NTP protocol uses UDP.
Maybe try pool.ntp.org and see if the cameras likes that better.
Or as an experiment use the time server IP address to see if the problem is name resolution (DNS).
I second the time synch tool above. It’s lightweight and easy to setup. Works great and keeps all your clients on your network for NTP. Pool.ntp.org has been known to have members that were tor exit nodes or serving malware in the past. Do it better, serve you own time :)
Thanks guys - I had windows server 2019 running and configured the in-built NTP server and it's working fine. All cameras in sync now. Appreciate the advice here
