Mods, this has a few questions regarding NVR's as well so it needs moved or deleted just let me know.
Hello IP Cam Talk!
Planning out my first install for my own home, and have a few questions:
From what I have read I think I want to go dahua from andy on this site. I'm leaning toward just buying a DVR and not messing around with a PC and blueiris or milestone.
I am currently looking at teh NVR4208-8P-4kS2 as the NVR, and a few questions.
1. Does this system work well with apps on android for internal viewing? (not worried about external - just local network) I would like to setup a tablet or something for my wife to view the cams easy.
2. I know it has 8 POE ports, but is it possible to add more cameras with a seperate POE switch? Or would I be better just getting the NVR4216-16P-4K?
I think I am going to start with 3-4 cameras. I mainly want to cover the driveway and the front and rear doors. I was originally under the understanding that domes were best for outside because it was hard for them to be turned/moved etc, but the more I read up on that, it seems that that is not the case. Maybe Turret? Not sure what is the best camera for soffit installation to look at doors. Budget on cams in around 125ish, but flexible if its worth it.
Any help would be great, and in the meantime i'll keep doing some research, and see what I can find.
Thanks!
Hello IP Cam Talk!
Thanks!
