- Dec 16, 2017
- 45
- 22
Just got a Hikvision DS-7616NI-K2 NVR and it lives in my home theater cabinet but the fan was WAY WAY too loud! I have great ventilation in there so it would have been nice if the fan was thermally controlled but nope, runs full tilt all the time
With all that empty space I figured I could fit a better fan in there and remove the stock one!!!
The offending fan:
I bought a DeepCool UF120 fan. It's got a rubber frame and comes with rubber "mounts" for the fan too for zero vibration noise.
I started by finding a place inside the NVR where the fan would fit with two hard drives still in there! Was very easy. Then, with the fan and everything except the hard drive(s) in the NVR I drilled mounting holes through the bottom of the case (through the existing ones in the fan). Then I screwed the fan to the BOTTOM of the NVR (i.e. on the outside) and traced the inside of the fan:
Then I removed the fan and motherboard from the unit and cut the shape out on my jigsaw. Worked flawless.
I needed a way to connect the fan to some power. These fans run awesome at 5v (silent but stills pushes a lot of air!) so I stripped the red hard drive wire (+5v) and one of the black ground wires (if you wanted to run the fan at full speed you could tap the yellow wire instead of the red) then cut off one of the molex to fan adapters that came with the fan:
I soldered the wires together, electrical taped it up, done and clean!
I re-installed the hard drive and motherboard and installed the fan using the rubber anti-vibration mounts it came with, flawless:
Still tons of room above the fan for it to breathe (between the top of the fan and the top cover case when installed):
Not much room under the NVR though, but if can't exhaust much air I could install some rubber feet on the metal feet of the NVR for a bit of extra height.
I turned off hard drive sleep in the NVR settings, told it to record 24/7, so will let it heat soak for a day or two then check the hard drive temperature. I just installed it right now, but it was still warm from the 48c it was running at before, so it's reading 37c degrees just after booting up for the first time, lets see where it goes from here.
Totally silent, lots of flow, exactly what I wanted.
-Jamie M.
The offending fan:
-Jamie M.
