i've been following  the Dahua Mod Kit forum of BoToX. And i'm stuck at adding another language for my cam - DH IPC1230SP-S2. I use this firmware : Index of /Firmware/IPC/Lite/HX1XXX-Eos4
The custom part is in the pd-x.squashfs, i modified it with adding Russian language but after flash on ly the pd-x.squashfs.img, my cam keep rebooting
Below is inside of the config file i use to extract,build the firmware but only the pd-x.squash :
from .config import *
DAHUA_FILES = OrderedDict([
("pd-x.squashfs.img", {
"required": True,
"type": DAHUA_TYPE.uImage | DAHUA_TYPE.SquashFS,
"size": 0x00700000
I added the Russian language file in attachment, also edit the i18n so it import the Russian text file
Can anyone take a look and help me at where i was doing wrong? Thanks a lot <3
update : i tried modify the English.txt and i18n with lang.py but after flash pd-x.squash through tftp, the cam still rebooting
"required": True,
"size": 0x00700000
