Just stumbled across the IPC-HFW5231E-Z12. Seems like it might be more "flexible" as a dedicated LPR than the IPC-HFW5231E-Z5. Price is not much different.
Best configuration is a 240GB SSD for the system disk plus a 2TB or more WD Purple drive for video storage.Thank you very much for that link. I never thought about simply getting a used cheap computer instead of a NVR. So I have read that there are "special" hard drives that are designed specifically for security systems I guess because they are constantly writing 24 hours a day. Would I need to purchase one of those to put in the computer? Also do you all just record 24 hours a day or do you set "trip wires" or motion zones to only record when activated?
And they've finally arrived. They are MUCH smaller than anticipated. The focus adjustment is relatively smooth, once it frees up and you run it forward and back a bit. But they did not come with any kind of mounting bracket or power supply, although both of those are easily sourced.There's an older post here somewhere by user @nayr about an 'I/R cannon' illuminator. I'll see if I can find it. There's also a later post mentioning a different product. Search phrase for AliExpress is "IR Illuminator adjustable focus"
This appears to be the same product originally mentioned by nayr
FYI, I've ordered two of these for the back yard where the turret's IR just doesn't quite reach the areas of interest.
Receivedthis bracket two days ago, and installed the illuminator beneath the eave near the downspout this afternoon.And they've finally arrived. They are MUCH smaller than anticipated. The focus adjustment is relatively smooth, once it frees up and you run it forward and back a bit. But they did not come with any kind of mounting bracket or power supply, although both of those are easily sourced.
