I've done some cursory research and seems I came to the right place (found several super useful posts from @wittaj )
I have an old Q-See system which I've run for almost 10 years and it recently died. Worked fine, though low resolution (and low end I know).
Since I'm upgrading, I figure I will go with IP (instead of BNC) and run new wires as a result (at least the holes are drilled!).
In doing reading here, it seems that an NVR isn't really the best option and I should go with a second hand PC and use Blue Iris. Can anyone confirm this would be worth the additional trouble for my use case? Also, any ballpark on what I can expect to spend? (camera options are also welcome
Requirements:
Current Setup I would like to duplicate with new setup:
Outdoor:
Indoor:
With my current setup I'm basically able to see all parts of my yard and any entry point into the house so it has worked well.
Thoughts? Opinions?
Thanks!
Requirements:
- 12 channels
- 4K video
- AI face recognition
- Would be awesome to have notifications when my dog in the living room is on the move.
- Good quality night vision (IR)
- Ability to view from my Mac and iPhone (in house and remotely)
- License Plate Reading (though this is more of a nice to have)
Outdoor:
- 3 cameras in the front of my house (front door and two sides) - front yard is only about 30' to the street
- 3 cameras on the side yards covering the gates and side door
- 2 cameras for the back yard (I've always struggled with ability to see at night with these) - back yard is about 100' deep
Indoor:
- Living room (covers the front door as well)
- Kitchen
- Basement
- Garage
Thoughts? Opinions?
Thanks!
