They do work for through hole stuff reasonably well, especially when paired with a foot pedal controlled aquarium pump.For the kind of soldering work I do that thing would be in the trash in less than five minutes.![]()
I have a cheaper Oki station (got a very good deal) and a generic hakko knockoff, an underwhelming hot air station, and a toaster oven with homemade pid control. Handsoldering anything smaller than 0203 isn't very pleasant. I need a better microscope.I have access to two Metcal soldering stations and just bought a new one last month, plus we have a variety of differnt tips to choose from which is really nice. We also have a microscope with LED lighting and a Hakko hot air torch which is a must when removing multi-pin SMT chips but you can easily mess up a PCB board or melt plastic connectors with it if you aren't careful. Sometimes I'll make heat shields with silver tape to protect surrounding components or use liquid solder mask, but I like the silver tape better.
I regrettably still have a box of wire wrap tools and prototypes (from 15 years agoI guess wire wrap is out too?![]()
This is what I liked on simple, 2-sided boards 70's through 80's.
It's a world of difference soldering different quality PCBs isn't it. Sometimes I wonder if the boards are even FR4 (I know some aren't, but I'm talking about ones that are supposed to be). Those old boards were probably mostly 2oz, but it seems like the soldermask was better too.The PCB boards and components from that ERA were built tough and could take a lot more heat before damaging anything but the PCB boards of today are cheaply made and consist of mostly SMT parts so it doesn't take much to damage the board or rip off a solder pad. Those things can usually be repaired but a simple ten minute soldering job could end up taking much longer if a pad gets damaged. I have a pretty good track record but for most people who regularly do soldering it's gonna happen to them sooner or later..it's just the nature of the beast.![]()
I regrettably still have a box of wire wrap tools and prototypes.
Yeah, it's a bit disturbing that I had to use it in 2008.That technology goes way way back!
For some reason, I just can not get the solder to go up the wick. I did as you said; put flux on the tip, placed the wick on top and put the iron on the wick. But the solder would not melt. I set my iron from 400F to 750F, but the flux would melt and smoke but the solder never melted. I've held my iron for as long as 20 seconds to no avail.What you want to use is a flux pen like this one from Amazon.. I use Kester brand for work but they're more expensive. For de-soldering you take the cap off the flux pen and apply the tip to whatever solder joint your removing and press up/down several times which will dispense the flux. Then you take the solder wick and place it over the now fluxed solder joint and then apply the hot soldering iron tip on top of the wick until the solder melts which will be absorbed into the wick. The flux evaporates quickly so you may need to repeat the process several times until the soler is completely removed and/or the part is released. To re-solder you install the new cap leads through the via holes and then apply flux right before you solder the joints. If you don't have any flux remover you can use a little isopropyl alchohol to clean any remaining flux off the board but it isn't 100% necessary. You might want to watch some Youtube videos on soldering techniques.
I don't know if the flux I'm using has anything to do with it. I bought this flux before seeing your suggestion on the flux pen;
I even applied more solder onto the tip but the new solder just balled up and never melted the solder that was on the tip. I have the solder remover with the bulb like the one on Gary's post but it never melted solder either. I'm baffled...
These are some of the better videos I've seen on the subject.Nice videos but I don't agree with some of the techniques they demonstrated. Not all soldering wick has built in flux and it's just the plain wick. I would never take a screwdriver to break free solder because that's a sure fire way to damage the board and just isn't the proper way to remove solder. The soldering irons they used are not very common and are too large for small SMT component soldering. I've learned the hard way that solder suckers can and will suck the copper pads right off the board so I only use them for very specific soldering tasks where I know they won't damage the board.
What kind of tip to you have on your iron? Is it a conical tip? Conical tips don't work that well compared to other styles of tip that are better at conducting heat where it needs to go. If you have one, I'd use a small chisel tip.For some reason, I just can not get the solder to go up the wick. I did as you said; put flux on the tip, placed the wick on top and put the iron on the wick. But the solder would not melt. I set my iron from 400F to 750F, but the flux would melt and smoke but the solder never melted. I've held my iron for as long as 20 seconds to no avail.
I don't know if the flux I'm using has anything to do with it. I bought this flux before seeing your suggestion on the flux pen; https://www.amazon.com/dp/B08KJRCYRH?ref=ppx_yo2ov_dt_b_product_details&th=1
Also @D!ngo, buy your capacitors from an electronics supplier like Digi-Key or Mouser, not places like Amazon or Ebay.
If you need help finding a suitable replacement for some of the capacitors, let us know.
