I need to set up a system to photograph a "stalker" and his mates, which are causing problems, typically once or twice a day. The stalker has had legal problems elsewhere, and has used guns, chainsaws and baseball bats to intimidate. Unfortunately, his home is next door... The legal strategy is to capture enough incidents to move the offending from civil to criminal offending, so as to generate jail time.
Im familiar with Dahua, so starting there. Needless to say, I need court quality images that clearly identify the offender, night or day. I need a minimum of 4 cameras to get the evidence and protect the system itself, two of which are probably going to be the evidence cameras. I don't want to spend more than 30 minutes a day processing recordings. Unfortunately there's a lot of foot traffic, so motion triggers aren't going to cut it to make the recordings manageable, there's probably 6 hours per camera of human motion, plus uncut grass etc. I can't steer the cameras during an event, so would benefit from a level of automation (e.g. zoom, human tracking). The stalker has been seen in the 20Hrs between 7am and 3am. The events happen between 5m and 15m from the cameras, but closer for an attack on the cameras. I'm expecting to buy 2.8 lenses to get a 110 FOV, any smaller and the amount of feeds to review grows....
The threat is likely to never go away, e.g. the system will be needed for many years.
The concept i'm hoping to realise is to use face and vehicle detection to index the recordings, possibly ANPR as well, to get the review time to a manageable level.
I'm heading towards:
- 2x IPC-HDW5541H-ASE-PV (5mp), or IPC-HDW5541H-ASE(8mp) monitoring other boundaries to capture vandalisation of the main cameras from outside the FOV?
- 2x IPC-HDBW71242H-Z (12mp evidence cameras)
- NVR ...
- Is this adequate or should I up-spec further?
- Does a WizMind NVR add value when you have WizMind cameras, or is it essential?
- What do you get for face detection by camera? Is it just a metadata flag added to the frame, that the NVR can index?
- Can any system identify a person who walks with their face obscured, etc.?
- Does face detection by camera identify the person, or is identification done by the NVR as real-time or post processing.
- Can face detection drive a motorised zoom?
- Can face detection pivot the camera and later return it to the normal position?
- Is 5mp adequate for closework?
- Assuming the 4 cameras feed in using H.265 ,do I need to worry about a system bandwidth of only 80 Mbps?
- On the assumption I might need a 5th POE, should I go 2*4POE NVR or 1*8POE NVR?
- I have one approach I haven't got covered (over the flat roof) of the single storey building that accommodates the cameras. May need two additional ports in the future, to get 360 degree protection of the host building.
- Can I filter the recording by face and/or vehicle plate number?
- Can I filter recordings to classify new faces and vehicle plates?
